Extreme USB 3.0 problem on Windows
I have huge trouble…
I got my Extreme USB3.0 flash drive 64GB and all works perfectly on my OS in MacBook.
Whenever I insert the drive to Windows computer it is not recognized… and want me to format it for max size 200MB. I attached some print screens from Mac and Win
Sory for polish language but thats mac’s system.
Any solution?
Buli
Anythink? Anyone?  :(
Hi, try this:
First make a backup of all information with your Mac OSX machine. Then (on windows machine)  download the SD Card Formatter Sofware  link: https://www.sdcard.org/downloads/formatter_4/eula_windows/index.html
On the Windows machine disconnect any USB device, and insert the USB flash drive, then open the “sd card formatter”, click on “Option” and select “Format size Adjustment: ON”,  and proceeds formatting.
The USB flash drive will be formatted in exFAT file system, compatible with Windows and Mac.
@bulipunk solved?
MAN! U R GR8!
ALL WORKS! HOPE THERE IS NO VIRUS OR SOMETHING! ;)
AND SERIOURSLY! ALL IS FINE! ALL IS GOOD!!!
CHEERS MATE!!!
