Dear SanDisk.
I am struggling to use the Extreme Pro ExpressCard Compact Flash Adapter with my MacBook Pro.
I have exactly the problems as described in the following knowledge base article:
However, removing the driver and installing the latest version as described in the KB article does not solve the problem.
Usually I can read my CF card (SanDisk Extreme 16GB 60MB/s) once. As soon as I try to remove the adabter or changing the CF card I get the gray screen of death. The problem is the same no matter if I use software eject or “Power off card” from the Mac OS X menu.
Here is my crach dump file. Maybe it can be useful?
Looking forward to a swift solution to this very annoying problem with an otherwise good product!
Best regards.
/David
