Explain firmware to me in detail.
What is it, what does it do, how to get it into my clip.
My spouse gave me a 2GB red Clip yesterday, I’ve done research, and I think I need firmware in order to load songs onto my player. It’s completely new, nothing done to it. And my computer has all it needs to get files onto the Clip.
Maybe I need something else, though. Not completely sure on how to use this yet.
Any help is appreciated.
IT doesnt need new fw to load, just for fixes and feature… my pref :: mount as msc (mass storage class) > music folder > drag n drop files… when you got what you want, use mp3 gain to normalize all songs > unplug.  when you get  to stuck refresh data screen (as today goes, you will get it) find the ongoing arguments to fix… the ones about formatting are wrong…
Firmware is the system software that the MP3 player itself runs.  Updated firmware fixes bugs, and enhances features of the player.  So I recommend you upgrade to the latest firmware.  You can see several threads on how to do this.
there is one thing… when you do update, just get the bin file and drop onto root and unplug…dont install the lame updater… dont ask why–been covered to death, search if you really wanna know… just dont do it
why do you have to normalize the songs?
gotcha :wink:
i just thought it had something to do with the player itself.  I mostly listen to live sets so i just like to keep the original recording the way it is, unless its to FUBAR’d to listen to.
