Hi there,
Just wondering if someone could shed some light on the following error message:
“An error has occurred while initializing U3 Launchpad: Drive is corrupted or unformatted. U3 Launchpad will close now. Please format the drive, disconnect the U3 device and try again.” I disconnect the drive and try again but the same error occurs.
The weird thing is that I am able to access everything on the drive but on a read-only basis - I only worked out there was a problem when I couldn’t save things to the USB. I have no problems at all on my home computer.
This has only happened since I have been added to a different network on my work computer. I have had problems before where the device is trying to assume a drive which is already on the computer but a different error message came up to the one I’m seeing now, plus the USB is not competing with another drive as far as I can see (by looking at My Computer).
This is about the extent of my technical knowledge so if you have any suggestions as to what I can do then I would be very grateful if you could put them in lay terms! As the problem only occurs on my work computer I don’t have admin access, so if I need to do/change anything with the device when I’m at work I will need to be able to relay any suggestions back to the IT helpdesk.
Best wishes
Pickles4
