**** Can anyone supply an answer to this messasge please? ****
Thank you
I think I did everything correctly.
I did try to convert a MPG file, but it wouldn't 'take.' I tried to convert an AVI video and that went through, but at the end of the convert, I got a pop-up saying something to the effect: "SanMedia Converter.exe has encountered a problem and needs to close....etc....." And then the Converter closed. What caused this and how can I correct?
The entire video did transfer to the E260.
Sorry, but I don't know what you mean by: "SplashScreen." (I am senior citizen and quite new to all of this.)
When I turn on the E260 I see a white SanDisk in middle of screen and then it goes to the next screen with Videos, Music, Settings, etc. When I click on the Settings/Info, I see: Version 0102.24A and then Memory/Free, etc.
Alice (for grandson Bobby)
BTW:
#1- Is there any way to stop the auto-check for updates when we open SMC?
#2- I notice a file name: Sansa Media Converter, in Folder -"C:\documents and Settings \ Owner\ Application Data\ SanDisk\ Sansa Updater" and the size is 104,437KB, which is quite large for this notebook. Can this file be deleted? Or must it remain?
#3- When I plug in the E260 to my computer, I get the following "Windows No Disk / Exception Processing....etc." See below image:
[URL=http://img56.imageshack.us/i/sansanodisk.jpg/][IMG]http://img56.imageshack.us/img56/6523/sansanodisk.jpg[/IMG][/URL]
I just click cancel on both pop-ups.
#4- When I plug in the E260 I thought the SMC is supposed to open automatically. That is not happening. Anyway to change so it does.
#5- Is there a Program installed by Sansa called: "geckofx?" I am getting a lot of AVG Resident Shield pop-up Warnings for Tracking Cookies regarding "geckofx." I believe these are all since we installed Sansa on grandson's computer. They are marked "potentially dangerous object." Add-on: Just checked and there is a "Geckofx" folder in my C:\documnets & settings\owner\local settings\application data.
Is this Feckofx folder put there by Sansa? If so, can it be deleted? I don't like these Tracking Cookies!
Can you advise please?
Thanks
Message Edited by bobbyz on 04-08-2010 01:17 PM
Message Edited by bobbyz on 04-08-2010 01:36 PM
Message Edited by bobbyz on 04-08-2010 05:30 PM
Message Edited by bobbyz on 04-09-2010 04:25 PM
Message Edited by bobbyz on 04-10-2010 05:36 PM
Message Edited by bobbyz on 04-15-2010 02:31 PM
