freesky2 wrote: Ok, I just took a hammer too it and destroyed it into many pieces. I will never buy a MP3 player from Sandisk again. Totally pissed ex-customer.
You have posted this multiple times in different threads. If you continue to spam, you will be banned for 24hrs to start
it seems that many of the things i would like to be able to do i can only do on a v2,
and since i didnt know this v1/v2 firmware info when i bought the player, i cant return and get it,
so my only hope is that the next firmware will ‘magicaly’ allow us to do this,
If still under warranty, you can always pray that your v1 pukes out, gets RMAed, and they send you a shiny new v2. That’s what happened to my v1, although I didn’t pray for it to happen, as I liked the Rockbox firmware on my v1. The really nice thing was being able to switch between the Sansa And Rocbox firmwares at will…
a new firmware should allow us to play other media rather than just music off the microsd,
and maybe even allow us to use sdhc cards as well…
There is a version 1 firmware wishlist here. It would be appropriate to post your requests to that thead.
Doing so, however, is a big fat waste of time. Not even one request on that thread showed up in the new firmware – Sandisk fixed a bug that no one complained about. The e200 is discontinued (or will be soon) and replaced by the Fuze. Sandisk has demonstrated, repeatedly and without exception, that they don’t give a rat’s xxx about customer requests. It is unlikely that v.1 firmware will ever be updated again.
The good news is, rockbox firmware provides many of these features (for the v.1 only, so far), if you want to go that route.
G’luck.
Message Edited by Twistedaura on 05-24-2008 02:38 PM
Be sure that the two firmware files are unzipped prior to transfer into the root directory of the Sansa. Also, have the device in MSC mose. Be sure to drag and drop the two files into the open Windows Explorer box, and NOT into any of the folders shown; this box represents the root directory.
If the transfer doesn’t work, unplug the Sansa, and turn it off.
Switch the LOCK / HOLD switch to the right (towards the headphone jack) with the orange bar showing.
Hold the REC button depressed while connecting the USB cable. Keep the button depressed until the device shows up in Windows Explorer (My Computer) as 16MB FORMAT. (Reminder: do not try “formatting” this reserved partition!!)
Drag and drop the two files into this wee beastie, and disconnect.
Turn the HOLD switch back to off.
Success?
Fingers crossed.
Bob :smileyvery-happy:
Message Edited by neutron_bob on 06-18-2008 04:24 PM
I went to update the firmware for my E280 to 01.02.24 from 01.02.18A. I can’t get this player connected to my computer. It keeps failing to install the driver. Consequently, there is no drive letter indicated. Where do I go from here???
Thanks for your help, Bob. The 2 firmware files were unzipped but still would not transfer. I unplugged the Sansa, turned it off, and followed the rest of your suggestions and was able to transfer the 2 firmware files into the 16Mb folder. So far, so good.
When I connect the Sansa e250 now, I can see all my music folders just like they were before. Only one MAJOR problem remains. When I try to operate the player, it thinks there is no music there. I didn’t reformat anything, and I’m pretty sure my music is still there. In fact, I checked to see how much memory is available, and it’s pretty much the same as before.
How can I get the player to realize that the music files are still on there???
This might be a simple problem. The PC is suddenly looking for a driver, yes? Were you using MSC mode for transfer?
The default USB communication mode may be set to MTP. As of late, Windows and MTP have proven to be problematic. The changes with Windows Media Player 11, and Vista, come to think of it, have required some tinkering.
Try setting your v1 to MSC mode and see if she’s back.
You can check in Windows Explorer for the current mode status of the device: if the Sansa is listed with a drive letter, it’s in MSC; if it’s listed under “other devices”, it’s in MTP mode.
Thanks again in advance for your help.
David
Have a look at the Music folder of the Sansa while connected in the SAME mode as used for transfer. Use Windows Explorer / My Computer.
Are the files there? Select under “folder view”: show hidden files.
In MSC mode, go into the SYSTEM folder and delete the DATA file in there. This is your Sansa’s database of files. When you disconnect, the database refresh message will pop up on the Sansa, and it will build the new database from scratch. Let’s see if the old one was corrupted.
i has a question, i have the sansa e260 v1 is the european version so it cant tune FM radio but maybe if i install the american firmware with FM radio enabled or the european firmware, can i have radio on my sansa??
@manda93 wrote:
yep i have tried that more then once… still not working…
Time for plan B. Load the firmware and bootloader files onto your device in Recovery Mode. You can also format the device to start with a clean slate, if you drop a New Folder renamed sansa.fmt into the 16MB partition that opens in this mode.
Remember, you will anger the Sansa gods if you try to format this partition with the PC- use the folder method only.
I´ve updated my player. But know I don´t know how to create playlists anymore…
At the last version i just had to go to the music folder then rightclick on a folder and then click create playlist. But now theres no “create playlist” button. When I choose play all the songs are all there but i want playlists. It ■■■■■ to go through 800+ songs. can you help me???
