Drives, drives, drives
Came home from vacation, to find my Mac no longer recognizes my WD external hard drive. Ive tried all the usual things (i.e. unplug power, use a USB cord from a working drive…). Looking for suggestions. Found my drive under ‘Legacy’ once but don’t find it now. Ugh!
Hi ibhux,
Is your showing up in the disk utility? Also, have you tried to connect the drive with any other computer?
No
No
Hi ibhux,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
