My Passport can’t be recognised by my MacBook
I just got a new HDD passport for my MacBook and while setting up, I accidentally unplugged it without ejecting the drive. After a while, I try plugging it in to my MacBook but unfortunately my Mac doesn’t recognise my drive and all it does is lit LED light and 6 clicking sounds. I also tried plugging it in to a wall socket to ensure that enough power is going through but it didn’t work.
Hi Brandon1313,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
