Does the sansa clip work with win7
I am having trouble syncing my music from my computer to my mp3 player - it worked fine when i had vista - but recently upgraded - now none of my music will sync after making playlist or anything - i thought that whatever was compatible with vista was fine with 7 as it (7) being backward compatible (maybe i was mistaken?)  but i really don’t want to buy a new one because this works great - my battery life is outstanding - i think i charge it every 2 weeks it seems like - anyway any help will be appreciated -thanks
I think you need to take a look at your syncing software–that or its settings may have been changed.
No problem recognizing the clip as a flash drive in MSC mode. I don’t use MTP, for that you would need the latest WMP should come with windows 7
