Does it matter which brand of Micro SD Card I use ?
Will Class 4 and a Class 10 make a big difference ?
Thanks
Anderson
Thanks
Anderson
Brand? No.
Class? Maybe. Some people have reported problems when using Class 10 cards. Others have no issues. Just to play it safe given the choice, I’d opt for a Class 4.
But will having a Sandisk Memory card better ? or it won’t make a different at all ?
Personally, I prefer to use SanDisk cards with SanDisk products but to be honest, it probably doesn’t matter.
I have an 8G Samsung micro SD HC class2 and my SanDisk will not even load it.
longest loading screen ever which produces only frustration, no positive results
do i have to get a new card? or is this a bum SanDisk that i should exchange?
Have you tried formattiing the card and putting a few files back on to see if that solves anything? Your long refreshing time could be (and usually is) file/ID3 tag-related.
See my other post “External SD” i have exactly the same problem with the same exact card,
