Is there a difference between WD Mybook Studio 3TB and WD Elements 3TB ?
I suppose it is a 7200 tpm DD for the MYBook studio. Is it the same for the Elements ?
Thanks
Thanks
Hi benm,
My Book Studio and WD Elements Desktop, both are desktop hard drives and require to connect with external power source using power adapter. Speed of an external hard drives may be depend on internal drive present in this enclosure, which is not specified by WD.
You may refer these links for technical specifications:
https://www.wdc.com/en-gb/products/wd-recertified/my-book-studio.html
https://www.wdc.com/en-um/products/external-storage/wd-elements-desktop.html
