I have SanDisk 64 GB 3.0 usb. It is formatted as exFAT. My system does not support exFAT. How can I permanently convert it to FAT32 permanently.
Hi @sandiskspam
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
You’ll need to reformat your SanDisk 64GB USB drive from exFAT to FAT32 permanently to convert it. Follow these steps on a windows computer:
- Insert your USB drive into the computer.
- Press
Win + R, typecmd, and press Enter to open the Command Prompt. - Type the following command and press Enter to list all drives: diskpart
- Next enter: ‘list disk’
- Identify your USB drive from the list, and
- type: select disk [number]
clean
create partition primary
format fs=fat32 quick
exit
Your drive is now formatted as FAT32.
