My computer crashed and I bought a new one. I am trying to retrieve my data from my WD backup drive. I can’t find the disc or software that came with my backup drive to load on my new computer. How can I tell which WD external hard drive I have. The model # is on the back of the drive, but it doesn’t tell me if its a “MY Book” or “Essentials”. Where can I download the software to install on my new computer? My WD drive model # is wdbaaf0015hbk-00.
The drive you have is a “My Book” drive and it came with a backup software called WD Smartware. You may download this software from the link below:
http://www.wdc.com/wdproducts/wdsmartwareupdate/wdsmartware.asp?id=wdfMB_Essential&os=win
You may also locate your backup files on the backup folder.
Go to “computer”, then go to the external drive and here you will find a folder called “WDSmartware.swstor”. Here you will find all the files that you have backed up using WD Smartware.
You may also have to enable Show Hidden Files to find it.
Joe
