Just started using this morning. I downloaded the secure access manager and tried to drag and drop files. On some files it will crash. The computer still recognizes the flash drive but when i open it there is nothing showing on the drive. The Icon is on my system tray but doesnt give you the option of opening it. Also when I plug it in it says it is automatically suppose to open the sucure access but it doesnt. I usually have to pull the flash drive out and re-insert it into the computer to get it to show its contents. definately fustrating.
" I usually have to pull the flash drive out and re-insert it into the computer to get it to show its contents."
Pulling it out, rather than Safely Removing it, can cause the Cruzer’s File Allocation Table to get screwed up. Try running CHKDSK for the drive and see if that helps.
