Connect Drive app not available
My Sandisc Wifi USB drive is useless now as i cant access it by wifi. I found out that you have retired Connect Drive app and it no longer would be available. I feel its unfair for users. I need a solution for this asap.
I understand your frustration. Since the SanDisk Connect Drive app has been retired, accessing the WiFi USB drive through the official app is no longer an option. However, you may still be able to access the stored data by connecting the drive directly to a computer via USB.
If you need wireless functionality, you can try third-party file manager apps that support WiFi storage, though compatibility isn’t guaranteed. If you’re facing difficulties retrieving your data, I recommend reaching out to SanDisk Support for further assistance.
