@miikerman wrote:
Perhaps you can specify the docking station and the amplifier–the Clip+ has been fine with my FiiO amps and with my car stereo system (using an aux cable connection).
hi
the docking station is an INTEMPO for ipod
the amp is a TEAC H255
both connected using an auxilary cable supplied with the docking station
@jk98 wrote:
Why use the docking station? You can attach a cable from the Clip+ headphone jack to any input on the receiver(except phono).
what receiver???
the docking station is the receiver
i want to use the docking station because it is small and compact for taking on holiday
it is a mini amplifier with built in speakers
i.e. it is a receiver connected by a cable to the headhone jack
i dont understand the relevance of your reply???
Probably misunderstood your set up as did I the first time I read it. Try setting the volume to high by going to Settings>System Settings>Volume High>Press the Center Button. Then when you hook it up turn it up, See if this is loud enough.
what receiver???
