I have a Clip sport I was working on my main pc. Now when I plug it in, it will say traferring, and then go to the main screen on the MP3 player, and doesn’t show as charging.
When plugging it in I will see it show up under USB as a Mass Storage Device, and I will also see it show up twice under the Disk Drives this is for about 5-10 seconds at max, it then will remove itself from both areas in Device manager. It will not see the device, and will not charge it.
If I plug it into another windows 10 computer, it works fine without issue. So I know it’s not the device or the cable, it appers to be something with this main PC.
Any help would be appreciated.
Thanks.
