Hi
I would to knwo how classify the songs by style (rock, jazz etc …) I have make a folder Rock but it don’t appear, but songs appear
If I want shuffle only rock how to to do ?
thanks
Hi
thanks
It sounds like you could use folder browsing if all of your songs are sorted by genre into different folders.
If that doesn’t work, you can add genre tags to your MP3s with a program like MP3Tag and then you will be able to use the “genre” section in the Fuze+ menu.
Ok thank you very much, I had not seen that I can see genre in the menu artists then to the left or right ![]()
