Change IP address of MPW
hi there,
my local network is 10.0.0.0 (not my real address …heheh)
how do i change MPW to this subset
Are you saying that you configured your MPW to NOT use DHCP (the default), but instead gave it a static IP that is now incorrect?
If that’s the case, then you can either change your network back to the old setting, connect to your MPW, change its IP, then set your network back the way you want it.
Or, you can just do the reset described in the manual.
have not configured it to do anything, it is straight out of the box.
want to use the dashboard to configure it to auto add contents of sd card when inserted.
OK
can now access the Dashboard, had to reset laptop, been playing around with network on it.
the ip address on laptop got stuck, so had to un-stick it. :-))
