Change in the remaining life, instability and SMART
In september I bought an SSD Plus 240G to substitute the 120G version (this disk was placed in another notebook). After the change I reinstalled all the system (Windows 7 x64), but there is some troubles.
  • I have noted that the “remaining life” is decreasing very fast compared with the 120G that had no change during more than 6 months. Now it’s in “98%”. I tried to check the SMART when I noted this. The fast test run without problems but the complet test stops and return the code “27” (stopping at 10%).
  • Besides that I noted many instabilities in the system. Many times the system crash. The screen stops to respond but the indicator of the disk shows some activity. This happen principally when I’m using the Chrome navigator. Many times the system crash after returning from the suspended state and this did not occur with the 120G version.
Thanks.
Health indicator is wrong (i sent a ticket about this issue and nobody cared)
Disks health frequency is 1% but program reads as 0,1% .
Can you post screenshot of SMART section ?
Hi ugurkrl,
My system is very unstable after replacing the SSD.
SMART data from CrystalDiskInfo 7.0.3 x64
CrystalDiskInfo 7.0.3 (C) 2008-2016 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Professional SP1 [6.1 Build 7601] (x64)
Date : 2016/12/03 17:05:40
– Controller Map ----------------------------------------------------------
  • Intel(R) Mobile Express Chipset SATA AHCI Controller [ATA]
  • SanDisk SDSSDA240G
  • TOSHIBA MQ01ABD050
  • DAEMON Tools Lite Virtual SCSI Bus [SCSI]
– Disk List ---------------------------------------------------------------
(1) SanDisk SDSSDA240G : 240,0 GB [0/0/0, pd1] - sd
(2) TOSHIBA MQ01ABD050 : 500,1 GB [1/0/1, pd1]
Model : SanDisk SDSSDA240G
Firmware : Z32070RL
Serial Number : 161974475804
Disk Size : 240,0 GB (8,4/137,4/240,0/240,0)
Buffer Size : Desconhecido
Queue Depth : 32
of Sectors : 468862128
Rotation Rate : ---- (SSD)
Interface : Serial ATA
Major Version : ACS-2
Minor Version : ACS-2 Revision 3
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 617 horas
Power On Count : 445 vezes
Host Reads : 3342 GB
Host Writes : 2018 GB
NAND Writes : 656 GB
Temperature : 43 C (109 F)
Health Status : Saudável (100 %)
Features : S.M.A.R.T., APM, 48bit LBA, NCQ, TRIM, DevSleep
APM Level : 0080h [ON]
AAM Level : ----
Drive Letter : C:
– S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
05 100 100 __0 000000000000 Reallocated Block Count
09 __0 100 __0 000000000269 Power On Hours
0C 100 100 __0 0000000001BD Power Cycle Count
A5 100 100 __0 028D02ED02DC Vendor Specific
A6 100 100 __0 000000000001 Min W/E Cycle
A7 100 100 __0 000000000000 Max Bad Block/Die
A8 100 100 __0 000000000008 Maximum Erase Cycle
A9 100 100 __0 000000000000 Total Bad Block
AA 100 100 __0 000000000000 Vendor Specific
AB 100 100 __0 000000000000 Program Fail Count
AC 100 100 __0 000000000000 Erase Fail Count
AD 100 100 __0 000000000002 Average Erase Cycle
AE 100 100 __0 000000000028 Unexpected Power Loss Count
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
BC 100 100 __0 000000000000 Vendor Specific
C2 _57 _38 __0 003E0000002B Temperature
C7 100 100 __0 000000000000 Vendor Specific
E6 100 100 __0 00F4002700F4 Percentage Total P/E Count
E8 100 100 __4 000000000064 Spare Block Remaining
E9 100 100 __0 000000000290 Total GB Written To NAND
EA 100 100 __0 000000001A9C Vendor Specific
F1 253 253 __0 0000000007E2 Total GB Written
F2 253 253 __0 000000000D0E Total GB Read
F4 __0 100 __0 000000000000 Vendor Specific
ssd seems pretty healty.
Maybe problem caused by 2nd disk.Try to reinstall windows. Probably problem isnt caused by ssd.And check disk connectors on pc.
And if you are sure , i recommend to install ssd to another computer , if problem still persists , ask sandisk for RMA.
This is strange. Why the second disk is causing problems and when I was using the 120G version there is no problem?
The system was installed from zero when I change the disk, using the most recent image of Win 7 and installing all updates. There is no chance to reinstall all the system just to test and find de problem.
Now, the Dashboard is showing 99% of remain life (change form 98 to 99?), no sense.
There is no error in SMART report and health cant decrease again… You should ask for RMA to sandisk. There is some serious problem in ssd / firmware and SMART can’t detect it. 98 to 99 is really strange , obviously faulty controller , faulty firmware or faulty nand issue.
And
“A9 100 100 __0 000000000000 Total Bad Block” Attrib is zero , this is unpossible on 15nm MLC ssd . Only SLC drives can shipped without any factory / initial bad block , even SLC drives there will few bad blocks…
Mine is 20 , most of people have around 15-50 initial bad block but you have 0 . Bad QC test , initial bad blocks didnt marked after production.
another thing is : Host Reads : 3342 GB
Thats impossible too with DRAM-less ssds without any compression .Waf is 0.318 . I didnt notice any of those when i wrote first reply but it does makes sense now , ssd fails when writing blocks. It cant even update SMART report or bad block list , initial bad blocks wasnt checked during production.
Only RMA can fix this issue
Can you share the SMART data from the SSD Dashboard ?
