Hi, I have a 3TB WD Elements USB drive and now want to repurpose the HD as an internal drive in my HP microserver. This worked fine with other drives I tried, but it turns out the WD has hardware encryption which means that though it mounts fine via USB I can’t get it to mount via SATA.
If I get all the data off the drive and then reformat it, will that make it behave like a normal drive, or does would it always need to be connected to the external board to work?
Ah OK, you may well be right - I had jumped to the conclusion as I couldn’t get this drive to mount and saw other people with WD drives reporting that the hardware encyrption gets in the way.
