Hello there
The problem that i have is that i can’t use my external drive (WD Elements)and that strange thing that i cant use it on my PC Windows 7 but i can use it on the labtop normaly .
So… first thing i pluged in the stuff and then after few minutes ‘‘Local Disk I’’ appears not WD or anything else and then when i try to access it ,it keeps loading and stays like that and then ‘‘Not responding’’
so please any solution ![]()
Hi, have you tried connecting the Elements on another USB ports. Can you also share the model # for your Elements drive?
