Cannot Format
Hello all,
I just bought a brand new 8TB WD easystore external hard drive. I installed it onto my Mac properly, but when I tried to format this drive to make it writeable, an error screen says there isn’t enough space available for this to occur. I tried erasing it to reformat it as Mac OS Extended (Journaled), and the message says “Unmounting disk. MediaKit reports not enough space on device for requested operation. Operation failed…”
“disk2s1” now appears in grey in the sidebar where “easystore” used to be in black. I’m running 10.13.2 High Sierra. I’ve tried partitioning the drive into 7.75GB/0.25GB. Perhaps this is an easy fix but I feel like I’m going insane and I don’t know what to do. Please help!
Mount Point: Not Mounted
Capacity: 8TB
Available: Zero KB
Used: –
Type: USB External Physical Volume
Owners: Disabled
Connection: USB
Device: disk2s1
I bought a brand new WD Easystore portable 2 TB HD in October, 2017, and just now, 5 January,2018, opened the package and tried to use with my iMac 5k Retina 27 inch, Late 2014 desktop computer, also running OS 10.13.2.
I am getting the same fail message you are - “MediaKit reports not enough space on device for requested operation.” This should not be the case as my iMac drive is 1.1 TB and is only one third full. This came up with Time Machine, but then Time Machine doesn’t see the HD. Using Disk Utility the HD shows as disk3s1 (yours is disk2s1). Nothing works trying to erase the disk - not the proper Mac OS Extended (Journaled) format or any other formats erase, although it opens a box that says it is erasing.
I have had the exact same problem this evening. Also running 10.13.2.
OK, here’s what fixed this for me.
Open Disk Utility (not in Recovery Mode) and change the View drop-down (upper left corner) to Show All Devices. Then select your actual device - not the indented volume - and then the Erase making sure the Partition Map Scheme is GUID and format is Mac OS Extended (Journaled). This should recreate your single volume as GUID/HFS+.
Here’s is what fixed it for me. I was able to use Disk Utilities on an older OS. I tried OS Yosemite and the configured using the partition instructions.
Try this link
For the moment, the USB flash drive turns inaccessible and can’t be formatted. I really need to be able to format it and make it normal to use, as it holds important documents FirstBankCard. Any help will be greatly appreciated.
HERE’S HOW: OK this is crazy. I’ve had several Passports and Easystores, so yesterday I bought another one. Went to format it to Mac OS Journaled using Disk Utility and it bricked instantly. Thought it was a bad drive, so returned/exchanged it. Drive #2, same thing. Found the solution on here: (1) connect the drive to your Mac, (2) open Disk Utility (3) in the far left sidebar, use the dropdown to change View to “all devices” (4) voila, the bricked disk shows up (5) NOW erase the drive, make sure you’re using a GUID partition and Mac OS Extended Journaled. Was up and running in a minute. WTF did WD do to their drives to cause them to brick when you format them?? It looks like maybe they partitioned the drive or put a Volume on there and that’s causing them to brick when you erase the partition using Disk Utility. SMH
For anyone still looking for this answer, I had the same issue on my iMac, trying to format a 14TB Easystore drive. Disk Utility would now allow me to format or partition the drive under any setting.
Here’s what worked for me: Right-Clicking on the mounted drive on my desktop and selecting “Erase disk”. For some reason, this allowed me to format the drive, even though the same function didn’t work in Disk Utility. Since doing this I’ve been able to Erase and Partition the drive in Disk Utility.
Hope this helps!
Try these steps:
  • Remove outdated Time Machine backups manually.
  • Locate and remove large files.
  • Minimize the data that Time Machine needs to back up.
  • Empty the Trash and turn off Trash for network drives.
  • Wipe the Time Machine backup disk and begin fresh.
This how-to guide should also be useful for you: Fix Time Machine Couldn’t Complete the Backup
