I have read from several people on the internet that the clip can record the radio but I havent been able to confind concrete evidence about it. I also read through the manual and nowhere did it say it does. I really hope it does because this was a big part of why I bought this product. If it does record the radio, how do I go about doing so? Can anyone help me please?
Welcome to the forum!
You’re right that it isn’t mentioned in the manual, but that’s just an oversight, I guess.
If your Clip version has radio, you can record it. There’s an option in the radio menu to record, play and delete recordings. Just hit the down (Menu) button 4 times when the radio is playing and you’ll find it.
This solution doesn’t work for my clip. When I have the radio playing and I click down 4 times to get ‘recording’, as soon as I press select, the radio switches off. Please help.
If you are playing an FM station, click on the bottom (submenu) button. Scroll down past Add Preset / Auto Presets / View All Presets / select Recording > Record Now.
Bob ![]()
Thanks, that’s wonderful. Didn’t seem to work when I did it before.
