Are you able to record the radio? Tehcnical support told me yes however it doesn’t say you can in the manual or on the box
Enter FM Radio mode
Tune to the station you want to record
Press the Sub-Menu button (the bottom button on the wheel)
Scroll down to highlight “Recording”
Press the center Select button
Make sure “Record Now” is highlighted
You are now recording your station. To stop recording, press the center Select button and choose to either save or not save the recording.
Hope this helps.
