Got my new Sansa Clip this morning, I’ve had it plugged in 10 hours and the battery indicator shows a full charge. I have adjusted the brightness level as high as I can and it’s not bright enough to see unless I turn the lights off in the room.
Also I when the song title is scrolling through, I can see the Sansa and computer icons faintly in the background where it is hard to see what the song title (or whatever) is.
Is this a defective clip? It came from Amazon.
Indoors, the Clip should be plenty bright enough.
Give us a wee bit more information about your Clip: how many GB capacity is your device?
With the device on, go to Settings > Info and read the first line of information, the firmware version.
No worries, I’m blonde too.
Bob :smileyvery-happy:
It’s hard to see, looks like it says Version 02.01 and something else behind it I can’t make it out it is so dim.
It’s a 2 GB
Ooops! I clicked on Accepted Solution and didn’t mean to!
You can reverse your ‘Accepted Solution’ boo-boo in the OPTIONS (upprer RH corner of msg.).
You can reverse your ‘Accepted Solution’ boo-boo in the OPTIONS (upper RH corner of msg.).
It sounds defective to me. Return it, the screen should be bright.
I returned it to Amazon this morning. It was very dim yesterday, today it completely disappeared. My replacement should be here tomorrow morning.
Calling all blondes, brunettes, red-heads…hair of all colors and even those with no hair! :smileyvery-happy:
I posted a few quick shots of my silver 4GB with the brightness turned to its lowest setting. I figure I have a normal unit…given that we don’t exactly have a library of shots to compare our units to, could you please take a look (shortcut below) and if yours is noticeably dimmer please note it!
http://forums.sandisk.com/sansa/board/message?board.id=clip&message.id=12137#M12137
Thanks,
-Matt
Message Edited by sansamatt on 12-05-2008 10:01 AM
