Current battery is finished. It is 3.7 v and 530mAh. All I can find on ebay are 750 mAh.
Is that a suitable replacement battery?
Yes, and better than the original. ![]()
Is it possible to find sansa batt 1000mAh and above?
I’ve never seen (or heard of) one.
LiPo (and basic Lithium cell) technology has improved over the past two years. There are 650mAh and 750mAh batteries readily available for the e200, with one source listing higher, if I recall, but the 750 is the one to get. I just siedthis oneon eBay.
They are also available online from Radio Shack, or you can have them deliver to your local store.
I assume that you’re looking for the e-series battery, there are c-series oneshere.
Bob :smileyvery-happy:
