I bought a refurb Fuze on Woot a few months ago, and I’m finding that the battery is showing about 1/3 charge after only listening for about a hour and a half. The other day, it was down to zero after about as much time (on the other hand, i listened to it for three hours yesterday and showed about 3/4 full).
I’m concerned that this thing may go belly up on me. Does Sansa support refurbs like they do for new ones? If so, do I have to register the device with them to get support, or can I just call?
Thankfully, the LiPo battery is available through Radio Shack. If you’re handy with a soldering iron, and careful with the clamshell, the battery can be replaced.
