Hi, I installed some MP3s on my C250, then removed them. Now i get all the titles with Bad Track when I try to play them. Also I have no storage space on it. Who do I fix it?
Buster
Buster
you mean how do you fix it?
What if you jut format the player through my computer. just right-click on it and select format.
you mean “what if you just format the player”
maybe
IF i
If I format the
If I format the player, will I loose all the data
If I format the player, will I loose all the data, and will be able to
Please do not post messages like this. One message post is sufficient.
Message Edited by Lil_Monsta on 08-07-2007 03:47 PM
