Bad Sectors
I have this 2TB My book that I have formatted several times with bad sectors. I have 3 windows 10 PCs that I have used to try to fix this drive. There is a program called Crystal disk that I would like to know if this can bybass or remap the sectors? When I checked the Drive the sectors bad where scattered everywhere. What program can I use on the drive to update the g-list of the drive, so that bad sectors get mapped and get put in a list so they are not available for further write/read procedure?
Hi there,
Try to write zeroes on the drive using Datalifeguard diagnostics, you can get this program from the following link:
Hope this helps.
Thanks , but I forgot to mention I tried that and it just took forever, after 4th day I quit the program
