I have a 1 TB WD Elements SE bought 2011 2012 made in Thailand.
From What I understand my drive have bad sector. The HDD Regenerator Program says bad sector and Hard Drive not there.
My computer shops says the hard drive is broken and I can not repair it.
I have another hard drive bought at the same time is there anything I can use to swap? I only care about the content on the first one.
HDD R program says I should use it as an internal drive but how do I do that?
http://www.dumpt.com/img/links.php?file=s3o9trmpgpvyahxgvo0g.jpg
http://www.dumpt.com/img/links.php?file=x6jps0pjyo9k8r8danrd.jpg
http://www.dumpt.com/img/links.php?file=qz65vqs05b1plmgt82il.jpg
http://www.dumpt.com/img/links.php?file=ddluc7em6cj23tzawyah.jpg
http://www.dumpt.com/img/links.php?file=qttce3fq09fty826v2v7.jpg
http://www.dumpt.com/img/links.php?file=1vysmrd6qcrcbbb8ckp7.jpg
I think I did this ![]()
8) For those who are able to see USB drive on explore – Never run Windows scan disk. This will mark all the bad blocks and render them useless.
anyway to get it back?
