Backup Report?
I just started using the passport backup, using the smartware software to backup my data each night at 8pm.   In the morning, I check to see if it has been completed.  The only thing to view is… click on the little clock and it shows the next backup is scheduled for that night at 8pm (date and time), and the it was last backed up the night before (date and time).
Is there not an actual report I can see that says how much data was actually backed up, gb or whatever???
Hello, from the Smartware backup tab, if you compare the two columns you should be able to see if the backup is complete or not. Check page 11 of the manual for more information.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705057.pdf
