Passport Ultra
How Do you know when all of your data has been successfully backed up?
If you are using the WD Smartware backup software then on the “backup” tab you should get a message that says “backup complete” or “backup accomplished”. You can also go into the backup folder and verify if all your files are there.
The backup folder is called “WDSmartware.swstor” and it is located on the root of your external drive.
