Backing up Multiple Drives .... Sleeping
Just purchased a Passport Black for my W7 PC. Will it even bu my internal hd’s even when my PC is asleep?
Hi, that depends on the software that you use, if you are using he WD Smartware or the WD Backup then the answer is no, as this software does not wake up your computer for backup. You might be able to use a third party software but I do not know any that can wake up the computer.
