I am attempting to update the firmware of a sansa express
I was unable to use the regular updater because of the windows x64 limitation. so I tried the zip file method. I downloaded the zipfile as suggested in the thread on updating the sansa express firmware; I put the driver in the proper directory and I was able to put the unit into sansa recovery mode by inserting the player while holding the volume - button and loading the driver; and the updater ran through the format portion and sat there. now, nothing can be done with the unit at all. it is registering as a 1GB storage device and nothing more. I subsequently found a “new” updater, with no 64 bit limitation, not mentioned in the above referenced thread, but it won’t recognize the unit, since it has been wiped clean. What can I do now? Isn’t there a file I can load onto the unit manually? Any help you could provide would be appreciated, since the only method everyone seems to be referencing depends on this zipfile’s updater which does nothing on my machine.
thanks in advance for any help you might be able to give.
win7
asusK50
2.2 GHz 3GB
sansa express 1 GB with no expansion card
