Okay so I had what seems to be a common problem with the Sansa e260 - can’t delete files from the computer, and noticed a bunch of strangely labelled folders under the MUSIC folder. I also couldn’t choose songs - ie when I selected a song from the sansa’s list, it would start playing whatever tune is six songs after the selected one!
I went to the Sansa website and followed their instructions to reformat. Here’s what I did:
backed up all my music to PC
selected MSC under USB mode on the sansa, then connected it to my computer
Under Format, I selected FAT32 (default) and reformatted. It went through fine.
checked for errors under check disk options
put all my music back on, in a file labelled MUSIC.
Here’s where we took a turn for the worse.
unplugged the sansa and it went through a system restart and refresh database
I was able to choose the correct song - but my “Billie Jean” had the picture of Eminem’s album cover…same deal with all the other songs! Some songs were also labelled incorrectly. I figured that would be easy to delete, so I plugged the sansa back in.
THERE IS NO MUSIC FOLDER. Just photos, videos, a folder called tmp and a file called VERSION.
- Checked the available space and I’m using more than 1G, meaning the songs I copied are definitely there…somewhere.
- The sansa is still ‘writing’. I’m afraid to unplug it because it has been writing for more than half an hour now.
I’d appreciate any help you guys can give me. Very unfortunate since my sansa has been working great the past four years.
Message Edited by sidewalkchalk on 07-04-2009 01:35 AM
