I recently bought an 8Tb My Book and had it working fine, except that as I was working it would power down and go to sleep between saves, so that when I went to save my work I had to wait about 10-20 seconds for the drive to power up and get running, which basically put my computer into pause until it was done. So I wanted to be able to extend the time the drive would wait while inactive before powering down; I saw that in order to do this I had to install WD’s software, where I could configure this. I first installed WD Discovery, which is what comes default in the drive itself to install, and then was prompted to install WD Drive Utilities in order to further configure my drive. I did so and finally was able to configure my drive so that it goes to sleep after 30 mins of inactivity… The issue is that now it NEVER goes to sleep. I can leave my computer, not touch it, and the drive just continues spinning. I’ve just watched an entire Netflix movie (a task that obviously has nothing to do with the drive, so it’s idle) and my drive has been spinning throughout.
My instinct tells me it’s WD Discovery–I mean, the name itself makes you think it’s something that “keeps an eye” on your drive, so I assume it keeps it running, at least in a reduced state. So I went ahead and closed all WD processes in the Task Manager and waited some minutes and, lo and behold, for the first time since I installed the WD software I heard the drive power down and have a rest. Of course, it’s now powered back up and is there, “idle”, but humming and making this little “brmm” noise every couple of seconds… so I imagine some WD processes just come back after a while…
As much as it pained me to have to wait for the drive to wake up every time I wanted to save my work, I prefer to have tit go to sleep, thus ensuring it will last me longer! It seems absurd that WD’s proprietary software makes the drive work worse than without it–but do I have to uninstall it to get my drive to go to sleep when idle? (And if so, is there another way I can lengthen it’s sleep time on a Windows 10 computer?)
