Accessories for Fuze plus?
Hi all:
I’ll need to changfe my Fuze as it’s wearing out after many years of good service.
The Fuze + looks very interesting but the main question I have are there any accessories for this new model?
Specifically, I’m looking for a polycarbonate case that can clip on to the belt and I can also use an armband when I’m in the gym.
According to the specs, Fuze + uses a microUSB connection. Excellent! So can I use any micro USB that are in the market?
Thanks!
xavier
yes to your second question about USB. I bought this on Amazon but the screen protector in it is ■■■■. YOU WILL NEED A SCREEN PROTECTOR OF SOME SORT
Amazon link: http://www.amazon.com/Items-Accessory-Combo-Sandisk-Player/dp/B0047HNP36/ref=sr_1_2?ie=UTF8&qid=1316696062&sr=8-2 it’s a silicon case.
alienkid10:
Thanks! I’ll definately get protector.I’ll buy one separately if the included one is ■■■■
xavier
also the AC adapter is weird you can’t control the player when plugged into it, but you can with other adapters no clue on car one though.
I think Alienkid10 may have been triing to indicate that you can not control the player directly when plugged into a computer, but you can when plugged into a AC charger.
You can control the player when plugged into a car changer.
no that specific AC adaptor is what I was talking about.
That is odd.  I have two ac adaptor.  Neither have a brand name on them.  One has a perminet cord.  I used the USB cable that came with my Fuse+ with the other.  I just tried both.  I can listen while it charge, I can change menus,  I can unplug from one and plug in the other with no interruption is sound or control.  Did your adaptor come with a phone.  I have two other AC adaptors. I will try them later.
no it came in the pack I linked above. Cableless I use my Fuze+ cable with it and I can’t control menus. I can set it up to play and plug it in and listen but once it’s plugged only working control is volume and lock.
I use belt case for sagem puma
I checked out the link from above.  This would seem like a good deal.  As I have said, my unit and changers work differently on all of my chargers from what you have discribed.  See if you or a fried have another AC charger.  Could be your Fuse+ Try the car charger.  Try the  cable that came with your Fuse+.
I use the cabel from the fuze+ and I tried the one from the pack with this and another charger one gave me control (a friend’s) this doesn’t the screen protector also has a sricker on it which leaves residue on OUTSIDE of the protector when taken off. A cell phone charge using mini-usb would work (android phone charger.)
Doesn’t the Fuze+ use a micro-USB connector, and not a mini?
I don’t know if the usb connector is an Android friendly mini/micro USB.  But I am sure the SD card slot is micro not mini.
yes sorry that was a mistype.
