The HTC One X’s large 4.7-inch display screen is such a wonderful feature. it’s a 720p HD display screen packed in to a chassis which reaches just 8.9mm thick. Plus, it is also coming up with Super IPS LCD 2 technology that, even though it does not have the brilliant color imitation of Samsung’s Super AMOLED range, truly offers games and videos to life. Obviously, with regards to videos play, the majority of us usually are not about to spend silly prices to buy or rent movies and TV shows we already possess in iTunes Store.
The issue with iTunes is the fact DRM attaches to purchased iTunes movies and TV shows doesn’t permit non-authorized devices to play. So to enjoy a protected iTunes M4V file, the device need to be authorized (using iTunes) with the account which was utilized to get the movie. Unluckily, you are only to realize that the Android gadgets didn’t obtain a permission to play DRM contents, which means iTunes films will not play on HTC One telephone.
Here Aimersoft DRM Converter is advised to convert iTunes to HTC One X backed DRM-free files. Just now download this program and begin with stepsbelow .
Step1:Add iTunes videos
Install the DRM removal and click “Add” button to load iTunes M4V movies to the program. You may as well put iTunes M4P music for converting. Besides converting DRM-protected iTunes media files, this DRM converter can also convert locked audio and video files downloaded and purchased in Zune, Amazon, BBC iPlayer, BlockBuster, etc.
Step2:Choose output videos format
Following movies and video are imported, you possibly can mouse click “Video files to” and select "MP4 Video " as being output format. (HTC One X supported video formats are 3GP, 3G2, MP4, WMV and MP4). If you’d prefer, you could click on the “Settings” button to change the resolution, encoder, frame rate, etc. For instance, if you need to play iTunes movie on HTC One X, you’ll be able to specify the video resolution as 1280*720.
Step3:Start converting iTunes video to HTC One X
Finally, just click the “Start” button in the lower right to begin converting iTunes to HTC One X. If the conversion completes, you could discover your converted video files by pressing “Find Target” and transfer these files to your own HTC smartphone without difficulty.
So now, you possibly can have fun with iTunes music and video on HTC One X without any limitaton.
Related guide:DVD to iPhone 5
