I recently purchased this 64gb stick.
When i tried to copy a 18gb file onto the stick i was getting the error that the file was to big.
I did some searching on the web and the problem was the stick was on Fat/fat32 format and can’t handle bigger files then 4gb.
So i formatted the stick to NFTS. It took several hours to format it, no quick format.
After the format was done, i still can’t copy anything to the stick.
When i check the properties, it says 0 bytes and nothing about the NFTS.
When i try to format it again, it just won’t start.
I just can see the drive under E: and thats it.
Plz help!
Update: I just tried the HP USB Disk Storage Format Tool. I can select the stick, but when i press start to format it, it says there is no media in the specified device.
When i check devicemanager and can’t see the drive, but i can see it under computer (ctrl+E).
