Hello all,
My 1TB WD My Book ( http://www.imagebam.com/image/9f4755294422177 ) is not working and every time I plug in the USB, it shows this popup window:
You need to format the disk in drive G: before you can use it
It’s not even showing the free and total size in Computer and when I click on it, it shows:
G:\ is not accessible
The file or directory is corrupted and unreadable
this is a chkdsk screenshot
http://www.imagebam.com/image/f4a1c9294422181
system used: Windows 7 64-bit
disk Format : NTFS
I have tried the following:
1- uninstalling the drivers from Device Management" and restarting my laptop
2- downloading/installing the MY BOOK drivers from WD
3- downloading/re-installing my laptops USB drivers
4- plugging the USB in all the 4 ports (one is USB 3.0)
5- turning on and off the external by pressing the button
6- plugging and unplugging the A/C power
I can try this solution as a last resort, but I’m not sure what to do afterwards.
Please help a brother out. I need my files back
