Not a complaint (I expect the ‘real’ capacity to be less than the stated capacity) – but just wanted to compare to other folks with a 16GB MicroSDHC card – do you also show 14.8GB capacity on it?
It’s very possible.
My 4gb card shows 3.78 before I put anything on it. My netbook at 160gb had really only 140gb (yes really!). I’m not really sure what happens to the rest, but I think just for processing what’s on it.
I have a 16GB player with an actual usable capacity of 14.7 GB, so I think your card is entirely normal. ![]()
To convert the manufacturer’s stated capacity to “real” gigabytes, multiply by 0.93. That won’t give you the exact number, but it’s pretty close.
Yes. Manufacturers advertise a GB as exactly 1,000,000,000 bytes. A true GB has 1,073,741,824 bytes. This is equal to 1024^3. In the 16GB case,
16,000,000,000 / 1024 / 1024 / 1024 = ~14.9 GB
