I have this is problem and i tried everything like diskpart and regitstery and all the programs and i found a method that i can do firmwork or software for it but I want the controller part number and in chipgenius and chipeasy it say controller part number unknown so I need help hereee
@saad
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
To find the controller part number:
- Try tools like USBDeview or HWiNFO.
- Check Device Manager for hardware IDs.
- Use the manufacturer’s software (e.g., Samsung Magician).
- Search online using the device model number.
