WOOO I'm so gonna RB this POS
well actually I sometime wonder if I have the device as the others :smiley: the touchpad on my device while not always very precise (picking sometimes the element above or under the one I want) is usually ok or even good. As far as I knoy it is not planned to use touchpad embedded gesture’s recognition in rockbox
meta: I think the same thing.
RHHHHHOOOOOO!!! I ve just played my first tetris game on the fuze+ with the gameboy plugin!! :smiley:
I can’t wait for a the coming correct touchpad impletation!!!
awesome. Meta : can you PM me on here when the second screen gets implemented?
alienkid10: If you have time it would be nice to keep in touch with us on the rockbox port - because you know the problem will not solve itself :smiley:
Pamaury just posted a a commit in the svn (just little thing, don’t expect a lot, but it could worth a try)
also could you tell us if the program is working under the grey screen? For exemple if you press power button for a few second does it shut down or do you have to wait for the hard reboot?
Pehraps we could send a message to developper to see if they have some tips for us?
I don’t know if it’s working. How long do you need to hold down pwr for to off it? Edit I’l hop on IRC Saturday So if you can compile it for me for then and send me the link (please zip up the .sb) I’ll test.
if you press pwr it should be down in 5 sec max else, if it is longer, it means the firmware hanged. Press power to turn it on. Wait 5 sec to be sure everything is loaded, then count many second you need to turn it off with pwr
so grey screen problem solved
kinda there are lines on the screen that make it look like an old TV.
Woo I RB this piece of (sound)! Lol.
:wink:
And yes, the screen will look like an old cathode ray tube-based tv for a while, but I’m sure that will get solved.
halonachos: that’s only for those of us with screen2. Anyone with screen one is fine.
Meta: for those who aren’t on the RB forum should they post bugs here?
@alienkid10 wrote:
 . . . for those who aren’t on the RB forum should they post bugs here?
No. If there are bugs or issues with RB, they should be posted on the RB forums. The people working on the project won’t see them here. People using Rockbox and have questions or issues to raise should register there.
Besides, while SanDisk knows about Rockbox and the work being done on their players (among others) they do not endorse it. Since this is a SanDisk sponsored and operated forum, it would not be appropriate to discuss those matters here. Casual discussion is fine; any more is not. :wink:
