Will not power on
When I press the power on button, the light on the front flashes, but the unit will not power on.
Hello videomama1,
Please specify the WD drive that you are using. Also, you can refer to the below link to know how you can physically connect, disconnect, and install a WD external drive on a Windows PC or Mac
https://support.wdc.com/knowledgebase/answer.aspx?ID=5316
