WD1600i032
Hello, I have a (very) old WD1600i032 external drive. Its connected to external power and to a Win10 laptop via the USB cable but Windows do not recognize the drive. Any ideas?
Thank you,
D.
Hi dimitriskourlas,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
Hi. I have this same issue. Brandon P did you have any luck? Get any support? I have old family movies stored on this drive and just discovered that Windows cannot find it any more.
Are there new drivers or anything that I can do so I can at least get my media off this WD1600i032 external drive?
Brandon P - my wd 1600i032 which I believe is a 160 gb external drive from a long time ago…powers up with green light around the big circle button, howwever my PC does not recognize. I connected to the original PC (which runs windows vista) and it does not show up in device manager or anwyhere. The drive powers on when I plug it in but the circle button or powering up/ down my PC does nothing. Did you have any luck with yours?
