Wd10000h1cs-00 - which AC Adapter (UK)?
I’ve here a 2006? Element harddrive without AC Adapter.
could you please let me know the specs fit with a UK (G) - Plug.
thx in advance.
BR
12 Volts / 1.5 Amps / 18 Watts
If you can’t find an AC Adapter to purchase … you can just simply remove the hard drive from the enclosure and put it in a 3rd Party Powered USB SATA Enclosure and it will work fine. Example
Have done it myself. Mostly because my old WD Elements was USB2.0 and the 3rd Party SATA Enclosure is USB3.0 … which make copying data a lot faster.
