is it possible to use WD Smartware on my latop when I am abroad to do backup on my MBL at home?
If yes, could you guide me because I do not see MBL in “Backup target”.
Thank you
Thank you
Hello HenriWD, you will be able to upload the files manually using the WD2Go/My Cloud app. But, currently you wont be able to do a automatic backup onver the internet using the WD Smartware.
Remote automated backup is the feature I need. Is there any plan WD do this in near future?
Are there alternatives?
Thank you
