WD Security doesn’t recognize my 4 TB WD Easystore drive. I checked WD Security: Supported Drives and it is not mentioned as the drive that is not supported.
Everything else seem to be working fine, but I want to enable encryption on the drive using WD Security
I have the same problem as the individual above. WD Security does not recognize my EasyStore 4TB Desktop. If WD Security is not supposed to work on the EasyStore Descktops why is the software included?
