WD Passport USB 3 Drive HSF Journaled is recognised but the drive won’t mount
I accidentally ran OSX Recovery Disk Assistant OS X Recovery Disk Assistant v1.0 on my USB HD .Then the Hard drive stopped mounting or showing up in Disk Utility .
It showed up in terminal though
On googling i found gdisk to be the only alternative after trying numerous software like Disk Drill,Disk Warrior,Paragon NTFS…, They all offered to recover my data.However i know that my data /all my files were intact.Just the partition map was messed up
I used gdisk and test disk. gdisk help me convert my MBR to GPT (after spend hours on it) and my drive then showed up in OSX Disk utility
“I Numbered the terminal commands for you convenience”
1.sanjeevvyas$ sudo gdisk /dev/disk1
GPT fdisk (gdisk) version 1.0.1
Partition table scan: MBR: protective BSD: not present APM: not present GPT: present
Found valid GPT with protective MBR; using GPT.
  1. sanjeevvyas$ diskutil list
    /dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *251.0 GB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_HFS MacPro HD 250.1 GB disk0s2 3: Apple_Boot Recovery HD 650.0 MB disk0s3 /dev/disk1 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *2.0 TB disk1
    The Partition shows up in my Disk Utility App but it doesn’t mount
  2. sanjeevvyas$ diskutil mount /dev/disk1
    Volume on disk1 failed to mount; if it has a partitioning scheme, use “diskutil mountDisk” If the volume is damaged, try the “readOnly” option
  3. sanjeevvyas$ diskutil readonly /dev/disk1
diskutil: did not recognize verb “readonly”; type “diskutil” for a list sanjeevvyas$ diskutil mount readOnly /dev/disk1
  1. sanjeevvyas$ diskutil verifyVolume /dev/disk1
    Error starting file system verification for disk1: Invalid request (-69886) sanjeevvyas$
    —> Upon analysis of another External HFS formatted drive i found i am missing an EFI EFI partition at id#1.I tried creating this with disk but was unable to
    sanjeevvyas$ diskutil list /dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *251.0 GB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_HFS MacPro HD 250.1 GB disk0s2 3: Apple_Boot Recovery HD 650.0 MB disk0s3 /dev/disk1 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *2.0 TB disk1 1: Apple_HFS 2.0 TB disk1s1 /dev/disk2 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *1.0 TB disk2 1: EFI EFI 209.7 MB disk2s1 2: Apple_HFS VideoUSBPASS1TB 999.8 GB disk2s2
Please help,I have already spent 2 days trying to salvage my files.I for sure know that there is a simple approach
Based on the information you have provided I believe your partition is corrupted and your will have to format the drive in order to use it again.
I recommend you try to recover the data using a data recovery software before trying to format the drive since this will delete all data stored in it.
Tnx,drive format was last resort…I used a data recovery software Disk Drill but it just groups similar files in folders so it’s useless .I just need to repartition the drives in proper structures so that it’s reads the data again which is still sitting in a RAW partition
anyways to do that
